Use this category:
Question 500 internal error when installing 5.2.4
5 years 7 months ago - 5 years 7 months ago #216879 by RittysMachine
This was posted twice in error.
Last edit: 5 years 7 months ago by RittysMachine.
5 years 7 months ago #216893 by rich
In your configuration report are the plugins enabled. Do you use all of this?
Kunena - Easyprofile Enabled: avatar=enabled
Kunena - Easysocial Enabled: avatar=enabled
Kunena - Gravatar Enabled: (this enables gravatars instead of avatars)
5 years 7 months ago #216895 by RittysMachine
Thank you, disabling the Kunena - Gravatar plug in gave me back the avatars.
I'm back to normal. thanks rich and xillibit.
Solved!
5 years 7 months ago - 5 years 7 months ago #216900 by xillibit
Jomsocial and Easysocial have both a class nammed CFactory, you have enabled both integration plugin. So i think the plugin integration tried to load the CFactory class from the wrong component, that can explain the erros in your first message
Last edit: 5 years 7 months ago by xillibit.
5 years 5 months ago - 5 years 5 months ago #217903 by vikrampaul93
Damm even I am having a similar kind of issue, I have searched all over the internet and even have posted on number of threads on different forum, no solution seems to work. I am really frustrated, can anyone of you here help me resolve this issue, I am very much tired now.   get-mobdro.com
Last edit: 5 years 5 months ago by vikrampaul93.
5 years 5 months ago - 5 years 5 months ago #217908 by rich
For a similar problem, create your own topic, please, and tell us the content of the com_kunena.log
Path is /administrator/logs
Last edit: 5 years 5 months ago by rich.
Time to create page: 0.145 seconds
