Use this category:
Question 500 internal error when installing 5.2.4
5 years 7 months ago #216866 by RittysMachine
Error when installing 5.2.4 onto Joomla 3.9.25, using Crypsis as the template.  Any assistance would be helpful.
I get this error when launching
Fatal Error: Method ComponentKunenaControllerWidgetWhoisonlineDisplay::__toString() must not throw an exception, caught Error: Call to undefined method CFactory::getConfig() in components/com_kunena/template/crypsis/pages/category/list/default.php on line 0
5 years 7 months ago - 5 years 7 months ago #216869 by RittysMachine
When turning Whoisonline to off (confirguation extra, Show Who is Online=no)
I no longer get the internal error but now get this error
Rendering Error in layout Category/Index: Call to undefined method CFactory::getConfig() in /home/crcci/public_html/components/com_kunena/template/crypsis/layouts/category/index/default.php on line 216
line 216 is         $avatar = $this->config->avataroncat ? $author
Layout was rendered in /home/crcci/public_html/components/com_kunena/template/crypsis/pages/category/list/default.php on line 21
Last edit: 5 years 7 months ago by RittysMachine.
5 years 7 months ago #216870 by xillibit
The error is related to an integration plugin, do-you have enable Jomsocial or easysocial integration plugin into Kunena ?
5 years 7 months ago #216872 by RittysMachine
With your advice I disabled JomSocial Integration.  That made the forum display.  I can read discussions.
Now the avatar of the members no longer display.
5 years 7 months ago #216873 by xillibit
I'am not able to reproduce your issue, with joomsocial intregration plugin enabled, i have not issue
Can-you put here please your Kunena report configuration settings ?
5 years 7 months ago #216878 by RittysMachine
htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 256M | Max file upload: 50M
Joomla default template details : CRCCI | author: Michael Carico - AbleSpark | version: 1.0 | creationdate: 08/15/2014
Kunena default template details : Crypsis | author: Kunena Team | version: 5.2.4 | creationdate: 2021-04-04
Kunena template params:
Kunena version detailed: Kunena 5.2.4 | 2021-04-04 [ Koios ]
Plugins: None
Time to create page: 0.161 seconds
