Use this category:
Solved Corrupted layout after install kunena 5.1
8 years 7 months ago - 8 years 7 months ago #198872 by WolfgangOWL
In Kunena 5.1 RC4 there is an issue with the Kunena menu. The menu is doubled when I reduce the browser window width.
is currently with RC4:
should be:
The reason is /components/com_kunena/template/crypsis/layouts/widget/menubar/default.php
current code:
<div class="navbar" itemscope itemtype="http://schema.org/SiteNavigationElement"> <div class="navbar-inner"> <div class="hidden-phone"> <?php echo $this->subRequest('Widget/Menu'); ?> </div> <?php echo $this->subRequest('Widget/Login'); ?> </div> </div>
should be:
<div class="navbar" itemscope itemtype="http://schema.org/SiteNavigationElement"> <div class="navbar-inner"> <div class="visible-desktop"> <?php echo $this->subRequest('Widget/Menu'); ?> </div> <?php echo $this->subRequest('Widget/Login'); ?> </div> </div>
Last edit: 8 years 7 months ago by WolfgangOWL.
8 years 6 months ago #198899 by rich
The following user(s) said Thank You: WolfgangOWL
Time to create page: 0.158 seconds
