Use this category:
Solved Corrupted layout after install kunena 5.1
- lusidjudjeto
I try both templates and also install lang pack but nothing help to make kunena template to work.
- lusidjudjeto
- Thank you received: 2545
- Holding on
- Junior Member
I am currently using Joomla 3.6.5 and Kunena 3.0.4.
In the 3.0.4 version, I note that I am getting quite a few error and menu messages so was wondering is it about time to update to a later version?
I have been reading the recent posting related to 5.01 and was wandering which is the safest version of Kunena to update to in view of comments on later versions?
I would welcome your advice with the pros and cons for each version
The cons: You get no support for your outdated software. And your Joomla and Kunena version includes unsolved vulnerabilities.
Advantagnes: Kunena 5.0 is stable and there are no known vulnerabilities.
If you have more questions, create your own topic please.
- Holding on
- Junior Member
I thought that my posing was related if I was considering installing 5.0.1, but I take your point on that.
Thanks for your kind words of wisdom
