Use this category:
Question Template issues ?
10 years 1 week ago #181654 by Alan-M
Replied by Alan-M on topic Template issues ?
Hello Rich, 810.
Carried out as requested, but again as you can see its the same
It's like it's not detecting the forum template at all ?
Thank you Both
Regards
Alan
"Mistakes are always forgivable, If one has the Courage to admit them"
10 years 1 week ago #181657 by rich
Replied by rich on topic Template issues ?
Please log out from your page and tell me whether the icons are correct then. Now I remember, that I had this bug at tests with a Joomla template. As admin the symbols were wrong.
10 years 1 week ago #181660 by Alan-M
Hello Rich
I have logged out and stays the same same, cleared cache & browsing history and again stays the same.
Its not detecting the forum template
Thank you
Regards
Alan
10 years 1 week ago #181661 by rich
What do you mean with " not detecting the forum template"? Crypsis has no the same structure as the template blue eagle. Please put a screenshot from your index page so we can see, whether is a difference between your and our browsers.
10 years 1 week ago - 10 years 1 week ago #181664 by Alan-M
Hi Rich
After looking at the "Blue Eagle" template I guess yes it look a lot more like that or a
phpbb3 equivalent, it had structure not like it looks now which I feel looks bland
If you're saying that is the correct look then is there a version of the "Blue Eagle" or equivalent
that can be used with Kunena 5.0.3 and Joomla 3.6.4. ?
Big Thanks
Regards
Alan.
Last edit: 10 years 1 week ago by Alan-M.
10 years 1 week ago #181670 by rich
Yes, your forum will displayed correctly. Crypsis adjusts automatically the style of the website. Currently there is no template like blue eagle for K.5. I know only the K5 templates, which are offered here from our advertising partners.
