Use this category:
Question Template issues ?
10 years 1 week ago #181577 by Alan-M
Template issues ? was created by Alan-M
Hi All
I'm having a small issue with the forum template on my site, just wondered if anyone has any suggestions how I might fix this :-
zantetravelguide.net/forum
Thanks in Advance
Regards
Alan.
Report Configuration
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 256M | Max file upload: 50M
Joomla default template details : RSJuno! | author: RSJoomla! | version: 2.0.26 | creationdate: June 2015
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.0.3 | creationdate: 2016-10-23
Kunena version detailed: Kunena 5.0.3 | 2016-10-23 [ Dibatag ]
Plugins: None
"Mistakes are always forgivable, If one has the Courage to admit them"
10 years 1 week ago #181582 by rich
Replied by rich on topic Template issues ?
Your Joomla template not uses bootstrap 3 framework. Please switch to Crypsis. If it is not correctly displayed, then select in Backend -> Kunena -> Templates -> Crypsis -> Basic Settings -> Load Bootstrap css = Yes
The following user(s) said Thank You: Alan-M
10 years 1 week ago #181595 by Alan-M
Replied by Alan-M on topic Template issues ?
Hello Rich
Thank you for your reply,, I tried what you said but still the same, I tried " Load Bootstrap css = Yes / Load Bootstrap css = No "
I also tried to load a different forum template but then I got could not locate the "XML" file ??
Thanks again
Alan
10 years 1 week ago #181596 by rich
It's not the same. Icons are missing and your menu items are not correct now. The menu items in the configuration report and on your page are different.
You must install it via "Kunena -> Templates -> New Template". But it works only with K5 templates.
First go to "Kunena -> Templates -> Crypsis -> Basic Settings" and enter in the field "Default category icon" icon-folder
Then click the next tab "Features" and select "Load External CDN Fontawesome = Yes"
Then repair the Kunena menus ( please see here ).
10 years 1 week ago #181598 by rich
It seems, that no symbols to be loaded. Try this code in your custom.css
[class^="icon-"]::before, [class*=" icon-"]::before { font-family: FontAwesome; }
10 years 1 week ago #181599 by Alan-M
Hello Rich
What location is that is that file please as I cant locate it
Sorry
Time to create page: 0.158 seconds
