- Thank you received: 1434
Use this category:
Question Template issues ?
Carried out as requested, but again as you can see its the same
It's like it's not detecting the forum template at all ?
Thank you Both
Regards
Alan
"Mistakes are always forgivable, If one has the Courage to admit them"
I have logged out and stays the same same, cleared cache & browsing history and again stays the same.
Its not detecting the forum template
Thank you
Regards
Alan
After looking at the "Blue Eagle" template I guess yes it look a lot more like that or a
phpbb3 equivalent, it had structure not like it looks now which I feel looks bland
If you're saying that is the correct look then is there a version of the "Blue Eagle" or equivalent
that can be used with Kunena 5.0.3 and Joomla 3.6.4. ?
Big Thanks
Regards
Alan.
Yes, your forum will displayed correctly. Crypsis adjusts automatically the style of the website. Currently there is no template like blue eagle for K.5. I know only the K5 templates, which are offered here from our advertising partners.
