Use this category:
Question Template problem for Kunena 5.0.2
10 years 1 month ago #180677 by 810
Please enable "Load Bootstrap" option on the crypsis settings.
10 years 4 weeks ago - 10 years 2 weeks ago #180919 by lagad
already done (i read the entire post).
here my problems :
box for connexion doesn't match very well with pictures :
and it is not possible to deconnect. --> Ok corrected with the last version !
with phone, it doesn't work very well : i need to select few time befor the box open.
I prefer to have each button for each action. --> Ok, corrected by kunena \ crypsis template \ parameter \ Show default actions = No
The choise doesn't work very well when i click on it, and with a phone, it doesn't work very well.
The text place is not long enough when i click on "answer".
i always need to readjust the box befor writing in it.
The button picture, video, and all the other doesn't work at all.
And I also have problem to size the picture and make them to have good look.
I don't really understand for what is for all the parameter of the avatar in the parameters of the template.
does it possible also to always have the "more information" open ?
--> Ok : on the crypsis options, clear the option at basic tab - Default category icon
I also noticed that on phone, when you read the "last message", it's only possible to go to the last message by choosing "new message".
But if you already read it, you cannot choose "last message", the link doesn't work at all.
I need to select the title of the message, then choose the last page and then go down of the page to see the last answer.
Thanks a lot for your answers.
Last edit: 10 years 2 weeks ago by lagad.
10 years 2 weeks ago - 10 years 2 weeks ago #181318 by lagad
nobody to answer me ?
is my question too bad ?
I also have the same problem as written here : www.kunena.org/forum/k5-0-support/138986...-on-the-topic#181064
10 years 2 weeks ago #181322 by 810
if you set a question, you need give us a link, and demo account, so we can check it. If you do only images, then we can't do anything, The issues are css conflict with your joomla template.
The following user(s) said Thank You: lagad
10 years 2 weeks ago - 10 years 2 weeks ago #181324 by lagad
Hy,
thanks for your answer.
template used : www.template-joomspirit.com/joomla-free-.../category_pathway-12
website : www.aslpaintball.com
waiting for your return ;)
edit : do you need an administrator acces ?
10 years 2 weeks ago #181326 by 810
.markItUpEditor { min-height: 250px; } .markItUpHeader ul a { padding: 14px; }
add this on the custom.less
backend - kunena = template - edit less - custom.less
and change option icon type: this will fix the double icons. and the category icons
backend - kunena - template - crypsis - features - Topic Icons set to font awesome
Time to create page: 0.146 seconds
