Use this category:
Question Template problem for Kunena 5.0.2
10 years 1 month ago #180584 by Jacques_1257
Hi there,
I just have updated kunena from 3.something to kunena 5.0.2, during the installation everything was alright but when I went to see the result was absolutely awful!!
It is probably a problem with the joomla template? or the joomla version (3.6.2)? or with a plugin?
This forum is our working tool and we really need it :( :( :(
How can I recover the older version? Help!
Thx in advance.
10 years 1 month ago #180587 by 810
looks like your joomla template doesn't support it. Then enable the "Load bootstrap" option on the crypsis template settings:
backend - kunena - template - crypsis - basic settings tab - "Load bootstrap" set to yes.
10 years 1 month ago - 10 years 1 month ago #180591 by BilboHouse
Hi to all,
I´m having a little problem with "Crypsis" template on a website, the icons like "login icon", "password, "more" and much more don´t show at the forum. I test it with firebug and changing or adding "s" at the class of the item appears. (this problem appears after upgrade)
ORIGINAL
<span class="icon icon-user"></span>
CHANGED
<span class="icon icon-users"></span>
Yo can show it at the attachments.
Best regards
Last edit: 10 years 1 month ago by BilboHouse. Reason: more references
10 years 1 month ago #180592 by 810
try adding this code on the custom.less file:
backend - kunena - template -edit less - custom.less
[class^='icon-']::before, [class*=' icon-']::before { font-family: FontAwesome; }
10 years 1 month ago #180593 by BilboHouse
Hi 810,
Thanks for your fast reply, I tried it and the solution don´t solved the problem. I erase the cache of the joomla yet with the same result.
10 years 1 month ago #180598 by Jacques_1257
Thank you for the reply, yes I think that this is a joomla template compatibility problem :(
Just as BilboHouse, putting "Load Bootstrap css" to YES didn't help…
I will try now to edit the custom.less file …
thx
