Use this category:
Question Template problem for Kunena 5.0.2
- Jacques_1257
I just have updated kunena from 3.something to kunena 5.0.2, during the installation everything was alright but when I went to see the result was absolutely awful!!
It is probably a problem with the joomla template? or the joomla version (3.6.2)? or with a plugin?
This forum is our working tool and we really need it
How can I recover the older version? Help!
Thx in advance.
backend - kunena - template - crypsis - basic settings tab - "Load bootstrap" set to yes.
- BilboHouse
I´m having a little problem with "Crypsis" template on a website, the icons like "login icon", "password, "more" and much more don´t show at the forum. I test it with firebug and changing or adding "s" at the class of the item appears. (this problem appears after upgrade)
ORIGINAL
Yo can show it at the attachments.
Best regards
backend - kunena - template -edit less - custom.less
- BilboHouse
Thanks for your fast reply, I tried it and the solution don´t solved the problem. I erase the cache of the joomla yet with the same result.
- Jacques_1257
Thank you for the reply, yes I think that this is a joomla template compatibility problem
Just as BilboHouse, putting "Load Bootstrap css" to YES didn't help…
I will try now to edit the custom.less file …
thx
