Solved Kunena export php tables to fix 404 error
3 years 1 month ago #229573 by Gindi
If you want to change the type and/or the collation in the database with phpMyAdmin, load the database and open the table by clicking on the name.
After the table has been loaded, click on "Operations" in the menu bar at the top.
In the field "Table options" you can set the type at "Storage engines" and the collation below.
Then click on "OK" in the "Table options" field on the right.
These changes can be made only in the tables.
Gindi
3 years 1 month ago #229591 by timpennington
Thank you!
That seemed to work, and it saved me a lot of time.
Very much appreciated.
Thank you
