Solved Own images for categorys
3 years 8 months ago #224779 by rich
Replied by rich on topic Own images for categorys
1) image path is url (../media/kunena/images/own_) ?
own_icon.png  is the name of the image I used for the example. You can also create your own folder. Then the image path must be adapted in the CSS code.
I need to edit this file   ..\components\com_kunena\template\aurelia\assets\scss\ "   ?
This code should be inserted into custom.css , but unfortunately this does not work yet. This bug will be fixed in the next Kunena version.
why does the forum cut off the full link????
New users do not have permission to add links to our forum.
3 years 8 months ago - 3 years 8 months ago #224800 by dimazik
Replied by dimazik on topic Own images for categorys
Joomla 4.2 Kunena 6.0.2
Its solved. Perhaps something is superfluous, you need the following steps:
1) Create a folder "ownimages" nearby with a "default", and put images of fcons there.
path is: media | kunena | topic_icons | "ownimages" | ownimage1,2,3,..
2)
3) Go to Backend > Components > Kunena Forum > Templates > Aurelia > Features > Icon Type > {select Images-Legacy}
3) Edit file custom-scss > components | com_kunena | template | aurelia | assets | scss |
.icon-1 { background-image: url("/media/kunena/topic_icons/ownimages/");
background-repeat: no-repeat;
width: 32px;
height:32px;}
I hope I didn't forget anything.
Last edit: 3 years 8 months ago by dimazik.
Time to create page: 0.457 seconds
