Solved Own images for categorys
3 years 8 months ago #224737
by dimazik
Own images for categorys was created by dimazik
I want use own images for categorys. Kunena 6.0.2
Documentation doesn't match Kunenа 6 and Joomla 4.1.5 versions
Where can I put my own category images and connect them? Thanks
3 years 8 months ago #224741
by Leen
With kind regards
Leen
Replied by Leen on topic Own images for categorys
do that Kunena Forum: Categories >your category >Category Icon:
with e.g fontawesome.com/v5/search?m=free
but set the Kunena template Aurelia setting to fontawesome
With kind regards
Leen
3 years 8 months ago - 3 years 8 months ago #224747
by dimazik
Replied by dimazik on topic Own images for categorys
Okay, it easy to use FontAwesome 5
But, what about solid and regular options of icons?
The light and duotone options is not available in FontAwesome 5.
What about icons size?
Last edit: 3 years 8 months ago by dimazik.
3 years 8 months ago - 3 years 8 months ago #224748
by Leen
With kind regards
Leen
yes had to do with the appearance of the icon
filled or empty thick thin.
you can test that yourself if you click on the small icon at the top left
fontawesome.com/v5/icons/address-card?s=duotone
and the size and color etc you will be able to adjust with css.
but then you have to go to kunena template at the functions tab
also enable this Load External CDN Fontawesome
With kind regards
Leen
Last edit: 3 years 8 months ago by Leen.
3 years 8 months ago #224749
by rich
Replied by rich on topic Own images for categorys
It's in principle the same as here. Only the image path is another.
docs.kunena.org/en/manual/backend/catego...-use-your-own-images
.icon-gs {
background-image: url(../media/kunena/images/own_icon.png);
background-repeat: no-repeat;
width: 35px;
height: 35px;
3 years 8 months ago - 3 years 8 months ago #224750
by dimazik
1) image path is url (../media/kunena/images/own_) ?
I shouldn't create a new folder with images?
2) I need to edit this file ..\components\com_kunena\template\aurelia\assets\scss\ " ?
3) why does the forum cut off the full link????
Time to create page: 0.247 seconds
