Solved Own images for categorys
Documentation doesn't match Kunenа 6 and Joomla 4.1.5 versions
Where can I put my own category images and connect them? Thanks
with e.g fontawesome.com/v5/search?m=free
but set the Kunena template Aurelia setting to fontawesome
With kind regards
Leen
But, what about solid and regular options of icons?
The light and duotone options is not available in FontAwesome 5.
What about icons size?
filled or empty thick thin.
you can test that yourself if you click on the small icon at the top left
fontawesome.com/v5/icons/address-card?s=duotone
and the size and color etc you will be able to adjust with css.
but then you have to go to kunena template at the functions tab
also enable this Load External CDN Fontawesome
With kind regards
Leen
- Thank you received: 2545
I shouldn't create a new folder with images?
2) I need to edit this file ..\components\com_kunena\template\aurelia\assets\scss\ " ?
3) why does the forum cut off the full link????
