Solved Template Icon Sets
5 years 1 month ago #219503 by nickza
Replied by nickza on topic Template Icon Sets
Hi
Thank you for the suggestions. Bootstrap 2 is select, and has always been selected.
When I changed to crypsis4, the forum style broke. The menu style was broken, and other things so I reverted back.
Its strange. Is there a way I can "reset" the templates 100%, even if that means breaking the forum for a bit? I just want to format the templates from scratch so I know we have a good base, but not mess up any of the configuration. I feel this is a files issue, not a config issue.
5 years 1 month ago #219504 by Leen
Replied by Leen on topic Template Icon Sets
yes you can restore the kunena templates to the default settings. when you open the template to change settings it should have a button at the top with Restore if you use it it will restore everything. but I don't know if he also puts back any changes made in the custom css of that kunena template. ps or have you sometimes made adjustments in the Website template? custom .css or user.css settings ? and that Crypsisb4 may be corrupting everything it may be arguing with maybe Bootstrap from website template maybe it has a setting on or off somewhere
With kind regards
Leen
5 years 1 month ago #219508 by nickza
It probably does have something wrong, which is why I suggested deleting the kunena forum files and starting from scratch without deleting the forum data. Seems that might easier than trying to troubleshoot forever.
5 years 1 month ago #219516 by rich
Replied by rich on topic Template Icon Sets
Crypsisb4 works only together with Joomla bootstrap4 templates.
The symbols which you not like, are the default bootstrap2 symbols, which are supported by your Joomla installation.
You can use Fontawesome instead, but there are no many difference (Crypsis setting "Icon Type = Fontawesome" + "Load External CDN Fontawesome = Yes").
Another possibility, if you have CSS know how, you can change the symbols via CSS. The symbols are defined via CSS code content.
Example:
The code for the Action symbol is
.icon-apply:before, .icon-edit:before, .icon-pencil:before {     content: "\2b"; }
Change the content with a content which you want. In this example the content for Folder+
If you add this code in your custom.less you have changed the symbol.
.icon-apply:before, .icon-edit:before, .icon-pencil:before {     content: "\e234"; }
You find all available symbols in the icomoon.css, path /media/jui/css/icomoon.css
5 years 1 month ago #219517 by nickza
Thank you for the reply. I used CDN Fontawesome, and it has solved the quote issue. Thank you
