Solved Template Icon Sets
5 years 1 month ago #219486 by nickza
Template Icon Sets was created by nickza
Hi there
I would like to use the default Icon Categories, and Icon Sets for Crypsis. Can anyone confirm the default settings for the Crypsis template settings for all of the icons.
5 years 1 month ago #219491 by rich
Replied by rich on topic Template Icon Sets
Check the Crypsis settings. Crypsis uses Bootstrap 2 symbols as default.
5 years 1 month ago #219494 by nickza
Replied by nickza on topic Template Icon Sets
There are a few things I want to fix.
They are attached.
1st is the quote icon
2nd are the buttons underneath the posts. arent there others? cleaner?
5 years 1 month ago #219496 by rich
1. In the text field should not be a symbol. Is your Kunena up to date?
2. Try the setting in Crypsis (tab Advanced) Show default actions = No.
5 years 1 month ago #219497 by nickza
Hi. Yes Kunena is 100% up to date.
That Show default actions - no is not what I meant. I like the default actions, I just dont like the button styles.
Thanks.
5 years 1 month ago #219500 by Leen
Replied by Leen on topic Template Icon Sets
take a look at the kunena template Crypsis Features tab to see if Icon Type really does have bootstrap 2 enabled.
And otherwise try as a test by Template : crypsisb4
set as default and then set it there
at Icon Type <> bootstrap 2 on .
is it better then?
With kind regards
Leen
