Solved Template Icon Sets
I would like to use the default Icon Categories, and Icon Sets for Crypsis. Can anyone confirm the default settings for the Crypsis template settings for all of the icons.
- Thank you received: 2545
2. Try the setting in Crypsis (tab Advanced) Show default actions = No.
Hi. Yes Kunena is 100% up to date.1. In the text field should not be a symbol. Is your Kunena up to date?
That Show default actions - no is not what I meant. I like the default actions, I just dont like the button styles.
Thanks.
And otherwise try as a test by Template : crypsisb4
set as default and then set it there
at Icon Type <> bootstrap 2 on .
is it better then?
With kind regards
Leen
