Solved Logout and Login Issues
5 years 3 weeks ago - 5 years 3 weeks ago #219446 by nickza
Hi
When users view a specific forum topic, or post, or even create a new post, they are logged in, but when they view the index/recent topics pages on the forum, they are logged out.
Very strange. Can anyone assist?
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : it_365news | author: InspireTheme LTD | version: 1.9.0 | creationdate: May, 2016
Kunena default template details : Crypsis | author: Kunena Team | version: 5.2.6 | creationdate: 2021-07-25
Kunena template params:
Kunena version detailed: Kunena 5.2.6 | 2021-07-25 [ Melia ]
Third-party components: UddeIM 4.0
Plugins: Search - Kunena Search 5.2.2 | Content - Kunena Discuss 5.2.2
Modules: Kunena Latest 5.2.2 | Kunena Stats 5.2.2 | Kunena Login 5.2.2 | Kunena Search 5.2.2
Last edit: 5 years 3 weeks ago by nickza.
5 years 3 weeks ago - 5 years 3 weeks ago #219449 by Leen
Replied by Leen on topic Logout and Login Issues
This looks a bit like what ever happened here ]read more
With kind regards
Leen
Last edit: 5 years 3 weeks ago by Leen.
5 years 3 weeks ago #219450 by nickza
Replied by nickza on topic Logout and Login Issues
Hi. No its not that. I think it has to do with a few things actually.
For example, on the home page there is a Latest Post Module active, but when we click on the link, it pull a URL from the footer menu. Which brings me to another question... Site-wide, should you have only 1 menu item linking to the forum? Because when I have more than 1 link, it wont let me use the same name... for example "forum". It forces "forum-1" and "forum-2" which is why i think this is causing this issue because when a user visits the forum with index.php/kunena/, everything works fine, but if they visit using index.php/forum-1, the forum menu goes blank, and a whole bunch of stuff breaks.
I hope that makes sense
5 years 3 weeks ago #219452 by Leen
mm with multiple menus to kunena forum would be possible provided other aliases have been made
but I can imagine if one does something in forum-1 for example and logs out of there then he is of course also logged out in forum.
(you can only log in to the forum once in that way)
ps.
but what is the reason to work with multiple forum's menu ?. wouldn't it be better to make a menu item to eg 1 specific kunena Category
With kind regards
Leen
5 years 3 weeks ago #219453 by nickza
ps.
To tell you the truth... I dont know what is causing this? I have hired a developer to take care of it.
5 years 3 weeks ago #219454 by Leen
I would then just go for one kunena Forum menu for example. Menus: Items (Main Menu) Menus: Edit Item > Forum > choose kunena > and there categories and disable the other menu items that point to the kunena forum. But be careful that you do that in your Main Menu and not in the Kunena menu. I say this because I can't see how your website is built a link to your website would be more useful to explain something I think
With kind regards
Leen
Time to create page: 0.170 seconds
