Solved Topic format and other issues
- littlepowell
rich wrote: The problem, the middle main column of your Joomla template contains the left main column.
Try this code at the end of your Joomla custom- or template css.
Code:#kunena { display: inline-block; }
Thanks. For some reason I can't get to the place needed to update the template. I click on the active template and it just brings me to the preview page. I am an administrator so it shouldn't be a permissions issue.. Hmm.
- Thank you received: 2545
- littlepowell
- littlepowell
rich wrote: I don't know this template. If you not have access via ftp then try this code in the Kunena custom.css (use the custom.css instead the custom.less file). docs.kunena.org/en/manual/backend/templates/edit-less
Wow that fixed it. Thanks!!
