Solved Topic format and other issues
- littlepowell
www.norbsoftdev.net/index.php/kunena/sce...cenario-editor#79905
- 9themestore
- Premium Member
Please try to switch the profile layout position or other kunena template to check your issue. I checked and found a lot of style conflict on your website.
Best regards,
- littlepowell
- Thank you received: 2545
- littlepowell
rich wrote: Go in the backend to "Kunena -> Templates -> Crypsis -> tab Advanced" and choose Load bootstrap css.
Thank you, this has helped a lot. The only problem now is there is a ton of space between the topic text and the body of the message. See example:
www.norbsoftdev.net/index.php/kunena/sce...-sdk-scenario-editor
Do you know how to resolve this?
Try this code at the end of your Joomla custom- or template css.
