Solved Topic format and other issues
6 years 6 months ago #213113 by littlepowell
We upgraded joomla a few weeks ago and everything in Kunena just looks...off. See the link below and you'll know what I'm talking about. There is a bunch of space in between the topic links, the layout is just a mess.. Any tips to resolve this?
www.norbsoftdev.net/index.php/kunena/sce...cenario-editor#79905
6 years 6 months ago #213114 by 9themestore
Hi littlepowell,
Please try to switch the profile layout position or other kunena template to check your issue. I checked and found a lot of style conflict on your website.
Best regards,
6 years 6 months ago #213116 by littlepowell
Thanks for the reply. How can I change the profile layout? i checked the different sections in the configuration and didn't find anything related to layout. Only thing is the default topic layout and I tried the different options (threaded etc.) and it didn't make a difference..
6 years 6 months ago #213123 by rich
Replied by rich on topic Topic format and other issues
Go in the backend to "Kunena -> Templates -> Crypsis -> tab Advanced" and choose Load bootstrap css.
The following user(s) said Thank You: littlepowell
6 years 6 months ago #213124 by littlepowell
rich wrote: Go in the backend to "Kunena -> Templates -> Crypsis -> tab Advanced" and choose Load bootstrap css.
Thank you, this has helped a lot. The only problem now is there is a ton of space between the topic text and the body of the message. See example:
www.norbsoftdev.net/index.php/kunena/sce...-sdk-scenario-editor
Do you know how to resolve this?
6 years 6 months ago - 6 years 6 months ago #213126 by rich
The problem, the middle main column of your Joomla template contains the left main column.
Try this code at the end of your Joomla custom- or template css.
#kunena { display: inline-block; }
Last edit: 6 years 6 months ago by rich.
