Kunena 7.0.8 Released
Solved How to put kunena navigation on top bar of my template
6 years 7 months ago #212166 by nhoj050789
But how can I put this whole kunena menu with the profile on the right, Same as original on the top of my page which its has already set a module position www.screencast.com/t/O6X0JQdXZJ when I tried to put it on module position the profile on the right is missing and I need to style manually the whole menu of kunena
6 years 7 months ago #212167 by Leen
I think it also depends a bit on the template used.
So I think something will have to be adjusted in a custom.css
And without a real link to the website, it remains a bit guessing
where the problem may be
With kind regards
Leen
6 years 7 months ago #212168 by nhoj050789
I used to adjust the original menu via css so it will push on my top page since its not working on module also I used query so its not affected the mobile then I think it works www.screencast.com/t/9W7oiXCQu
