- Thank you received: 2545
Solved [SOLVED] Changin Category icon using Font Awesome
This doc which you have read is for topic icons and not for category symbols. Maybe we discuss two different issues.
- webmasterinaffitto
- Junior Member
- Thank you received: 1
rich wrote: What you want to change? Category icons or Topic icons? The topic title is "Changing Category icon using Font Awesome".
I mean Category icons. In that document is talken about both of them.
Anyway, today some icons were shown since yesterday, today not are shown... I really not understand what's wrong.
I've written also to font awesome contact email...
No, that is only for topic icons. Here is the doc for category symbols. docs.kunena.org/en/manual/backend/categories/category-iconsI mean Category icons. In that document is talken about both of them.
In your case, you must only to enter the symbol in the category setting
Enter in the category setting
fa-exchange-alt
and
fa-shopping-bag
- Junior Member
I've contacted fontawesome developer and they say me that there is a version problem on the template of the forum, this is the reason for why some times icons appear and other no.
If I active CDN from crypsis template I've seen that the link for the awesome icons is the version 4.7 meanwhile into the actual fontawesome website there are the 5.0.12 version.
Could you change it into crypsis template? I've changed in mine and seems works.
Thank you
- Junior Member
rich wrote: Thanks for the hint. We have already changed it in the new Kunena 5.1 versions. Therefore it has probably only worked for me and not for you. I had created the image in my previous post with the K5.1-dev version.
Perfect! I can't wait to be released the stable K 5.1
For now I'm using 5.0.x and for this I've to use the 4.7 library.
Thank you
