- Thank you received: 1
Solved [SOLVED] Changin Category icon using Font Awesome
- webmasterinaffitto
- Junior Member
I've tried to change some category and topic icon following steps shown into the guide: " www.kunena.org/docs/en/faq/own-topic-icons " but I just can change the topic icone and not using FA...
I don't understand why! I've followed the example of the guide but when I've finished the result is a white space instead of the icon should appear...
Anyone can explain it better?
Ex. Into the guide there is the example for "car" icon and it says to write "car" after "fa=". I've done the same with "smile" icon. Into the Font Awesome website the "smile" icon is named "smile" and into the tags is named "far fa-smile". I've tried to put into the kunena template xml: "smile", "fa-smile" and "far fa-smile" but always appear a white space never the FA icon
- Junior Member
- Into "CSS suffix class forum" I've put the first part of FA "class" parameter. Ex. "fas"
- Into "Category icon" I've put the name of the FA icon. Ex. "fa-adjust"
Without touching any file into topic_icon, as the online kunena manual says.
The problem is that some FA icons appears, someothers no... but not understanding why
Any ideas?
- Thank you received: 2545
- Junior Member
I meant the Crypsis template setting. With external Font Awesome you should get all symbols in Kunena.You find it in the template setting (tab Features).
If you do not want external Font Awesome, maybe this pages help you:
fontawesome.com/get-started?from=io
renniestechblog.com/information/27-insta...for-a-joomla-website
- Junior Member
Some icons are displayed correctly, some others no. All of them are free so I don't understand why.
For example:
If I want put this as a category icon:
fontawesome.com/icons/exchange-alt?style=solid
It shows a blank image, instead of icon.
If I put this:
fontawesome.com/icons/shopping-bag?style=solid
It works good....
Why?? :blink: :blush:
