Solved [SOLVED] Changin Category icon using Font Awesome
8 years 7 months ago - 8 years 6 months ago #199117 by webmasterinaffitto
Hi all,
I've tried to change some category and topic icon following steps shown into the guide: " www.kunena.org/docs/en/faq/own-topic-icons " but I just can change the topic icone and not using FA...
I don't understand why! I've followed the example of the guide but when I've finished the result is a white space instead of the icon should appear...
Anyone can explain it better?
Ex. Into the guide there is the example for "car" icon and it says to write "car" after "fa=". I've done the same with "smile" icon. Into the Font Awesome website the "smile" icon is named "smile" and into the tags is named "far fa-smile". I've tried to put into the kunena template xml: "smile", "fa-smile" and "far fa-smile" but always appear a white space never the FA icon :(
Last edit: 8 years 6 months ago by webmasterinaffitto.
8 years 7 months ago - 8 years 7 months ago #199119 by webmasterinaffitto
I've done some experiments and I've seen if I use the following setting into category configuration I got good result:
  • Into "CSS suffix class forum" I've put the first part of FA "class" parameter. Ex. "fas"
  • Into "Category icon" I've put the name of the FA icon. Ex. "fa-adjust"
Without touching any file into topic_icon, as the online kunena manual says.
The problem is that some FA icons appears, someothers no... but not understanding why :( (obviously I'm tring only free icon, so without charge)
Any ideas?
Last edit: 8 years 7 months ago by webmasterinaffitto.
8 years 7 months ago #199133 by rich
Your Joomla template must to support the Font Awesome fonts, otherwise you must to load external the Font Awesome. You find it in the template setting (tab Features).
8 years 7 months ago #199151 by webmasterinaffitto
I've created the template on my own, but not understand why some icons are visible and other not...
8 years 7 months ago #199159 by rich
I meant the Crypsis template setting. With external Font Awesome you should get all symbols in Kunena.
If you do not want external Font Awesome, maybe this pages help you:
fontawesome.com/get-started?from=io
renniestechblog.com/information/27-insta...for-a-joomla-website
8 years 6 months ago - 8 years 6 months ago #199188 by webmasterinaffitto
I'm using the external FA parameter into Crypsis template and I'm using the name of the FA icons into .ini files as explained into kunena manual.
Some icons are displayed correctly, some others no. All of them are free so I don't understand why.
For example:
If I want put this as a category icon:
fontawesome.com/icons/exchange-alt?style=solid
It shows a blank image, instead of icon.
If I put this:
fontawesome.com/icons/shopping-bag?style=solid
It works good....
Why?? :blink: :blush:
