Kunena 6.4.13 Released
Solved users emails are showing, when the option is disabled.
8 years 9 months ago #196268 by doberk
rich wrote: This setting is related to the Kunena template. Try it with Crypsis, and you will see the email button is gone, you should report it your template author. Maybe there already a update for this.
Yes, you´re right, with Crypsis this settings works good. Thank you.
And what about my second question? is there any way to remove the "More" button and show the user features all the time?
8 years 9 months ago #196278 by rich
Different problems should not be dealt within a topic, even if it is only "a additional short question".
Create a Template Override . i don't know your template, but with Crypsis are it the lines 81 and 82 in "/components/com_kunena/template/crypsis/layouts/user/profile/default.php".
Remove line 81 and in line 82 "display:none;"
8 years 9 months ago #196455 by doberk
Nice, this is what I was looking for. Thanks. And sorry for my multiple question. I will have it in mind in the future :)
