Solved users emails are showing, when the option is disabled.
8 years 8 months ago - 8 years 8 months ago #196208 by doberk
In kunena configuration I´ve set "Show email" to "NO", and in the user profile, in forum options, I´ve set "Hide email" to "YES". However, the link to the user mail is still showing in both user profile and user messages.
¿Is there any additional configuration?
Thanks in advance.
Last edit: 8 years 8 months ago by doberk.
8 years 8 months ago - 8 years 8 months ago #196209 by rich
You are logged in as Admin or Global Moderator? Then you can see the address. You must test it as normal registered user.
Last edit: 8 years 8 months ago by rich.
8 years 8 months ago #196214 by doberk
Hello, thanks for reply.
I have checked it as guest user. You can check it yourself, this is the website: www.f1losdominguitos.com/index.php/foro/categorias
if you click on "More" button located below the user profile you can see total messages, location and email address. You can see it without registering, as a simple guest user. A registered user can see also the PMS button (uddeim integration).
I could remove email address with CSS, with "display:none" property. But I would like to know why doesn´t the configuration work.
By the way, how can I remove this "More" button. I would like to show the info always, without have to click. Is it possible?
Regards.
8 years 8 months ago #196220 by rich
Please add a configuration report: docs.kunena.org/en/faq/configuration-report
8 years 7 months ago #196226 by doberk
Here you have:
htaccess: Missing | PHP environment: Max execution time: 120 seconds | Max execution memory: 256M | Max file upload: 64M
Joomla default template details : jsn_megazine_free | author: JoomlaShine.com | version: 1.1.0 | creationdate: 04/29/2016
Kunena default template details : JD Newjersey | author: Joomdev | version: 1.0 | creationdate: August 2016
Kunena template params:
Kunena version detailed: Kunena 5.0.11 | 2017-09-03 [ Kinkajou ]
Third-party components: UddeIM 4.0
Plugins: None
Modules: Kunena Latest 5.0.3
8 years 7 months ago #196236 by rich
This setting is related to the Kunena template. Try it with Crypsis, and you will see the email button is gone, you should report it your template author. Maybe there already a update for this.
Time to create page: 0.325 seconds
