Solved Rsform to Forum post
10 years 5 months ago #175717 by CprlRst
Replied by CprlRst on topic Rsform to Forum post
Thanks for the input the 404 error occurs when clicking the forum post made via the above addition to the database so I'm thinking I have like half the post creation sorted but missing a key component
10 years 5 months ago #175718 by sozzled
Replied by sozzled on topic Rsform to Forum post
As I wrote earlier, without knowing anything about your website, it's next-to-impossible analyse the cause of your problem. 95% of "HTTP 404 Not Found" errors in Joomla are related to the menu—I am taking a wild but educated guess. So, how have you set up your forum menu?
10 years 5 months ago #175719 by CprlRst
The actual forum works fine if you post using the forum all is great but when trying to mimic a post from rsform using the mapping function clicking the post gives a 404 error. I will make a sample site to show the error
10 years 5 months ago #175722 by CprlRst
ok i have setup the test location
johnmaguire.org.uk/index.php/forum/welcome-mat
there you can see test post that gives a you do not have permission to view which seems what the 404 error was being confused with by the site owner.
if you click form from the menu it will show the form thats trying to be added to the forum.
i hope this helps a little
10 years 5 months ago #175724 by 810
Replied by 810 on topic Rsform to Forum post
try to create a new topic, and look the differents in the tables, I think the message are on hold, or the category settings are wrong.
10 years 5 months ago #175725 by sozzled
CprlRst wrote: OK I have setup the test location. ... If you click form from the menu it will show the form that's trying to be added to the forum. I hope this helps a little
Yes it helps a lot. You're right, you get a "You do not have permissions to access this page." (which is not the same as a HTTP 404 Not Found error).
I think 810 is on the right track. It's possible that the message may be pending/on-hold or that the category setting permissions are out-of-whack with the forum configuration settings.
