Solved Small Images Resizing
- WolfgangOWL
- Senior Member
Kunena Forum: Configuration
Maximum Image Width 800 px Larger files will still be uploaded but downsized to that limit.
Maximum Image Height 800 px Larger files will still be uploaded but downsized to that limit.
The above setting is GREAT, I don't want someone uploading a 2400px X 2400px image to the forum and with the above settings, if they do, it is RESIZED to 800px X 800px. So the config is working as far as this goes.
Now, here is were I, we are having a problem with the config settings.....or lack there of.
If I try to up an image with the size say.... 121px X 121px it uploads the image....
BUT....it blows the image up to the config setting size of 800px X 800px instead of 121px X 121px
HOW DO I STOP THE "ENLARGING" OF SMALLER UP LOADED IMAGES.
- WolfgangOWL
- Senior Member
I have no problem to understand what the problem should be. I just can't reproduce it. On my website "Maximum Image Width" is set to 800px. Images wider than the maximum width are resized to that value. "Maximum Image Height" is set to 800px, too. Again, images higher than the maximum height are resized to that value. Images smaller than the set values keep the original size.sabo wrote: This shouldn't be that hard to understand.
I do repeat myself: a link to the website in question could help. Wild guess is not helpful.
Setting 800 x 800
When I upload the image above. The size still stays 370 x 115
- Bewellfarmer
- Junior Member
- Thank you received: 3
Part of the message is hidden for the guests. Please log in or register to see it.
