Question Subscription Problem
10 years 7 months ago #174520 by sozzled
Nikiniko wrote: I still have the problem the box is always checked when I reply, but in the settings it is not set to be checked.
This is a new "feature" of K 4.0; I wrote an explanation in Kunena 4.0.5: changed subscribe checkbox “behaviour” angers community .
10 years 7 months ago - 10 years 7 months ago #174539 by Nikiniko
I read it, so i have no hope to fix it ?
1) Components » Configuration » Users » Subscriptions » Check Subscription Box (as shown in the image below)
is not working for me
2) This is the new arrangement:
Your users will need to edit their Kunena profile. If your forum does not allow users to edit their Kunena profile (for example, if you use Community Builder or JomSocial profiles with your forum) then this procedure will not work.
3) One of the developers posted a hint to help users change this behaviour by running the following SQL command:
UPDATE `#__kunena_users` SET `canSubscribe` = '-1'
where # is your Joomla table prefix.
The above SQL command is untested and may cause corruption or loss of important forum data.
Use at your own risk.
Is there something else i can do ?
Is really bad if you are in a forum to receive 30-40-50 mails per day.
For small forums maybe is ok
I am kunena 4.10
Last edit: 10 years 7 months ago by Nikiniko.
10 years 6 months ago #174968 by Nikiniko
Can anybody help with this ?
Makes members stop posting.
10 years 6 months ago - 10 years 6 months ago #174969 by 810
CB has now the option canSubscribe from kunena. So users can enable it or disable it.
Or add a new menu item on the forum that's lead to the kunena edit page.
Last edit: 10 years 6 months ago by 810.
10 years 6 months ago #174972 by Nikiniko
CB ?
you mean community Builder?
I use easy social nothing in common.
What do you mean with this ?
Link to Edit Kunena profil ?
Are you sure that this is possible together with easy social profile ?
10 years 6 months ago #174973 by 810
Backend - menu - kunenamenu - new - Menu Item Type = "Kunena Forum -> Edit User" -
Parent Item = "Forum" - Access ="Registered" - Add title = "Edit Profile" - save - change ordering - Save again
