- Thank you received: 5
Question Subscription Problem
after every post in a topic i get suscribed
Subscription Box is set to no
I reverse and reverse again setting because if i remember in the past i resolved this problem this way.
Is it bug maybe ?
is like the template instalation is changing the settings.
There are a probably a few topics in this forum that may help you but, I'm sorry, I'm not entirely sure I know what is causing your particular problem. Good luck with solving your problem "your way".
If i will need help i will ask already half road is the post.
Now if you want to investigate the bug, is something different and i can post you the configuration report.
I don't think this kind of attitude will get you sympathy. I have suggested to you what might help and, if you don't think this is helpful, I respect your opinion. You also have to respect my view that I'm only trying to assist you if you really want help.Nikiniko wrote: Dont get pissed , i dont do it to piss you but to bother you less.
I don't think that it's necessarily a "bug" with K 4.0. As I mentioned earlier, there are many topics in this forum that answer questions about "subscription problems" that may help you. Choosing which topic(s) that relate to your specific issue, however, is a bit more difficult if you don't want to provide some more details about (a) what version of Kunena you are using, (b) what configuration settings you have defined, or (c) how you may have defined your Kunena profile settings. These pieces of information, taken together, will help to point you more quickly to resolving your problem.Nikiniko wrote: If i will need help i will ask already half road is the post.
It's not a case of me investigating whether this is a "bug" (as you've called it)—investigating bugs is something that the developers will or will not do. I'm only trying to help you. Finally, it's your choice if you decide to provide your configuration report; it really doesn't matter to me if you choose not to do that. On the other hand, you could be waiting a while for an good answer.
