Solved captcha not working
- Thank you received: 2545
I try to remove everything and restore the upload?
Try it with the Joomla default template Protostar.
Google re-captcha there are two keys.
- The first says: "Use this key in HTML from your site to users." I use this key in "Public Key reCAPTCHA".
- The second says: "Use this key to communication between your website and Google. Make sure you keep it secret." I use this key "reCAPTCHA Private Key".
is this correct?
We have had this discussion before . The Kunena developers have no intention of supporting Google reCAPTCHA V 2.0 for the Blue Eagle template.
In summary: use the Kunena configuration settings if you want to use CAPTCHA for Blue Eagle; use the Joomla plugin settings if you want to use CAPTCHA for Crypsis.
I hope this helps to explain the current situation.
