Solved captcha not working
10 years 10 months ago #172543 by mahagonny
Replied by mahagonny on topic captcha not working
I'm about to lose hope. also recommends doing as you sozzled, nothing changes
10 years 10 months ago #172546 by 810
Replied by 810 on topic captcha not working
if you set the settings on kunena, Then try to disable the recaptcha plugin. Also do clean cache. Then you can try it again. ALso it can be a browser cache. So clean also your browser cache.
10 years 10 months ago - 10 years 10 months ago #172549 by sozzled
Replied by sozzled on topic captcha not working
810 wrote: if you set the settings on kunena, Then try to disable the recaptcha plugin.
I do not think this is a wise suggestion. There may be other reasons for using the Joomla CAPTCHA plugin (e.g. user registration, other Joomla extensions that utilise the Joomla CAPTCHA plugin) if site owners want to use Google reCAPTCHA V 2.0.
For the time being, site owners who want to use Google reCAPTCHA V 2.0 with Kunena V 4.0 are required to use Crypsis. Site owners cannot use Google reCAPTCHA V 2.0 with K 4.0 Blue Eagle but they can use Google reCAPTCHA V 2.0 for other things in Joomla if they wish; therefore there is no need to disable the plugin.
Last edit: 10 years 10 months ago by sozzled.
10 years 10 months ago #172551 by mahagonny
nothing to do. Now I sleep on it and tomorrow I will try again
Good night and thank you for your patience
:kiss: :kiss:
10 years 10 months ago #172552 by 810
@Sozzled
i said that because i want to know, if recaptcha is working at all on his website. Maybe wrong id numbers or conflict with other plugins/joomla template.
10 years 10 months ago #172553 by rich
Replied by rich on topic captcha not working
@mahagonny
Sorry, but how do you test? Your forum is offline since long time ago. So you can test only as admin and not as registered user.
