Solved File Upload Remote
11 years 2 months ago #168436 by cromaplus
Replied by cromaplus on topic File Upload Remote
So it's something that has not yet developed but can be inserted in short, I am not good at writing plugin for joomla, I need someone to do it because I can not make the plugin. I wanted to change my website and used as the main component Kunena, but I lack this particular, I need that file attachments are loaded remotely and not locally.
11 years 2 months ago - 11 years 2 months ago #168437 by sozzled
Replied by sozzled on topic File Upload Remote
I'm not saying if it's a good thing or a bad thing to enable a "remote file upload" feature within Kunena. My personal view is that, if you want the necessary space to store files uploaded by your users, you should purchase a hosting plan that gives you the space you need. That is actually the easiest and quickest way out of any space restriction problems that you may have.
On the actual issue about the technical feasibility of enabling a "remote file upload" feature within Kunena, we have had similar discussions on this in the past.
When someone says that they require forum attachments to be located "remotely" (i.e. not on the same server as the website) why is this really needed?
Yeah, I know that cloud storage is all the rage these days but clouds have been known to "leak" , too. ;)
Last edit: 11 years 2 months ago by sozzled.
11 years 2 months ago #168440 by cromaplus
I have a dedicated server, but I need this, I know that there are different opinions, is the cloud is fashionable today, but I use it for different reasons and now that I want to make a change to my website and I wanted use as the main component Kunena I need to figure out if I can do this or I can not do this.
