Solved Kunena Poll does not work
6 months 1 week ago #234982 by kboth
Replied by kboth on topic Kunena Poll does not work
<as there is the option in config to allow edit of polls,> could you tell me where it is to be found.
My Internet-Connection is down in the moment I'll help out by using my phone's hotspot and its sloooooow. so actually I dont work in the Backend of my site :-)
6 months 1 week ago #234983 by Leen
Replied by Leen on topic Kunena Poll does not work
Hi
I believe you can enable that in
Administrator Kunena Configuration > Extras at the bottom
With kind regards
Leen
6 months 1 week ago #234984 by kboth
Great, that's fantastic. I couldn't resist after all and decided to give it a try, at least in the test system. It works perfectly.
6 months 1 week ago - 6 months 1 week ago #234985 by joomod
Replied by joomod on topic Kunena Poll does not work
Hi
yes, I know how to enable it, but where/how can I use it on an active poll (no button or similar)
edit:
ok, got it in CKEditor (just use edit and then click the poll button - poll values are shown)
but this doesn't work in SCEditor, because clicking the poll button doesn't fetch the actual settings
Last edit: 6 months 1 week ago by joomod.
6 months 1 week ago #234986 by Leen
hello
As the creator of the poll, I can log in on the front end, then choose edit post, and just click on the poll icon again, and then I can add options.
With kind regards
Leen
The following user(s) said Thank You: joomod
2 months 3 weeks ago #235220 by it-support-group
Hi Polls still not work with SCEditor.
No poll button at all.
I have a 7.0.8 version on Joomla 5 as a test installation.
With CKEditor the poll button is there but not active. It changes, if I create a post and edit it, then I am able to create a poll.
Btw. with my kunena 6.3.10 poll is active with SCEditor and CKeditor.
But the Tooltip is wrong: COM_KUNENA_SCEDITOR_COMMAND_INSERT_POLL instead of "Polls"
Here I could find it with searching the file content:
./components/com_kunena/template/aurelia/assets/js/sceditor.js ->
tooltip: Joomla.Text._('COM_KUNENA_SCEDITOR_COMMAND_INSERT_POLL')
