Solved Kunena Poll does not work
6 months 1 week ago #234976 by kboth
I wanted to post a poll on our Kunena forum. Polls are enabled.
When I create a new topic, there is no 'Poll' icon; instead, I see a row of empty icons and, at the end – when I hover over it with the mouse – 'Comm_Kunena_sceditor_Command_insert_poll'. See Screenshot 1.png. When I click on that, I can enter a title and options, but it isn’t saved.
best regards
Karlheinz Bothmann
6 months 1 week ago #234977 by kboth
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 256M | Max file upload:
Joomla default template details : cassiopeia | author: Joomla! Project | version: 1.0 | creationdate: 2017-02
Kunena default template details : Aurelia | author: Kunena Team | version: 7.0.4 | creationdate: 2026-04-19
Kunena template params:
Kunena version detailed: Kunena 7.0.4 | 2026-04-19 [ Git Repository ]
Third-party components: CommunityBuilder 2.11.0
Plugins: None
Modules: Kunena Latest 6.0.2
6 months 1 week ago - 6 months 1 week ago #234978 by joomod
Replied by joomod on topic Kunena Poll does not work
You are right.
I don't know why you don't get the icon, but the translation string is missing.
I tested the poll, and besides the popup dialog nothing is happening, no entries in wysiwyg or bbcode view.
So the next point I must look for a solution.
btw. if you don't handle images in your forum,
you may try the CKEditor (see running here) , which is better coded (but haven't test the poll function yet)
(change in template settings - bbcode - 1st option)
Last edit: 6 months 1 week ago by joomod.
6 months 1 week ago #234979 by kboth
Replied by kboth on topic Kunena Poll does not work
Thank you very much. I carried out this initial test on my test system. Apart from the fact that there is no image on the button, creating a poll there worked fine. I was just confused because the poll isn’t displayed until you’ve submitted the topic. I then found that in the documentation. I find that inconvenient, especially as you can’t make any corrections either...
In the production system, it looks normal, meaning the button does have the icon. Otherwise, it works exactly the same in PROD as it does in TEST.
(My test system is a copy (using Akeeba) of the PROD system. -- My main focus was actually on testing the update to PHP 8.5—first in TEST, then in PROD )
Best regards
Karlheinz Bothmann
6 months 1 week ago #234980 by kboth
Thank you very much for pointing out CKEditor. The display is now perfect.
6 months 1 week ago - 6 months 1 week ago #234981 by joomod
so you say, the poll works in SCEditor?  cause I didn't get anything (not in preview and not in forum)
edit:  got it,  forgot to enable poll in this kategorie
so it would be better to disable the poll button, if it is NOT allowed in the active category to avoid confusing
as there is the option in config to allow edit of polls, have you found out where/how this can be done?
I could not find out (no button or something in view or edit mode, also tried the reset function)
Time to create page: 0.162 seconds
