- Thank you received: 13
Question set image size in posting not working (reason for my former problem)
in Kunena5 (don't know v6) the code looked like [img size=150]*
*may be if an admin will try to edit this post CK Editor will not work because of this tag
but having this in a posting in Kunena 7 CK Editor won't open to work with.
now in Kunena 7 I cannot find how to set the image size in CK Editor,
even if it is set (by using SK Editor) CK Editor ignors the params.
so how can wet set the size of inline images in CK Editor ?
and also:
SK Editor does not fully work
setting the size on an inline image gives the expected preview,
BUT in the normal posting view the image is still original size
you see, the size setting of an img is declared (included as width), but not CKEditor or SCEditor are giving a size attribute to images.
so how can we set image size ?
[img] => works, but no size settings
[img=200x67] works in SC preview, but not in forum view CK removes the size setting
[img size=200] works in SC forum view, but not in preview CK does not open in working mode
why (where?) have you disabled the images size and property settings in the basic image plugin?
this is what the image insert dialog looks like normally:
btw. also the upload option could be helpful, (using config to disable)
- Thank you received: 2545
can you explain in which file Kunena disables the image property settings ?
(in not in the ckeditor_config, may be in the image.js but Kunena has minified them, so hard to read).
I would like to experiment a bit more.
also do you know/see why CK Editor skipps if there is an attribute in the image tag (not depending on the value)?
