Important Upgrade problems
9 months 3 weeks ago #234422 by ruud
Replied by ruud on topic Upgrade problems
the errors you are getting are actually not errors but notices: this means that Kunena should work correct.
Notices should only be displayed while a site is in development, not in production.
You can (read: must! as exposing these messages is actually providing valuable information for hackers) turn these notices off in Joomla Global Config:
in Joomla back-end > System > Section 'Setup' > Global Configuration > tab 'Server' > set 'Error Reporting' to 'None'
Joomla will now not display these notices again.
New version of Kunena or following the instruction of Rich will resolve the root cause of the notices.
Hope this helps.
sharing = caring
9 months 3 weeks ago #234424 by sbeaver
Replied by sbeaver on topic Upgrade problems
Thank you for that advice. I had entirely missed/forgotten about the error reporting option and that will help me make the site usable again. Following Rich's advice has made the error messages much less prominent but I would still like to learn how to get rid of the last remaining errors. There seem to be quite a few reports of problems involving the social media system and this error.
I must also thank you for one of the most polite and well written responses I have ever received on a support forum. :)
9 months 3 weeks ago #234425 by ruud
Good to hear it helped. And thanks for the compliment 😀
Regarding remaining messages: difficulty here is that what is okay with php version x will get obsolete with future php versions. When that is decided (to make it obsolete) php will start showing notices so developers are notified: "fix this as in future version it will not work anymore"
When found, these notices are resolved in an updated version (in this case of Kunena).
So always (if possible) update to latest version, and when you run into one of them report them here on the forum so a developer can fix it.
Same goes basically for other extensions / Joomla core as well
sharing = caring
