Important Upgrade problems
9 months 3 weeks ago - 9 months 3 weeks ago #234408 by sbeaver
Upgrade problems was created by sbeaver
I have used Kunena for about ten years. Over that time I have kept Joomla and Kunena up to date with only minor issues. Today I attempted to update from 6.3.10 to 6.4.8 and it did no go well. My whole Koomla 5 site has gone down with hundreds of "Creation of dynamic property Kunena\Forum\Libraries\Config\KunenaConfig::${social/Twitter/image etc}  is deprecated" type errors being displayed. I cannot get to any part of my front end, nor the Kunena section of the backend. Attempting to upgrade the language pack gives an "Invalid extension" error.
Reverting to PHP8.1 fixes it but that is not a good solution. How can I fix this?
Last edit: 9 months 3 weeks ago by rich. Reason: Configuration report removed
9 months 3 weeks ago #234410 by rich
Replied by rich on topic Upgrade problems
I have removed the configuration report. Please do not insert any code tags in the report.
These error messages should only be temporary and should disappear as soon as you open the Kunena dashboard and afterwards reload the page.
9 months 3 weeks ago - 9 months 3 weeks ago #234411 by sbeaver
Replied by sbeaver on topic Upgrade problems
Thanks. I rolled back tp php 8.1 so that i could access the kunena back end. I visited dashboard, config and tools sections. After I went back to php 8.3 the same errors occured and I could no longer access either the front end or the kunena dashboard. I'll try that procedure again though.
Last edit: 9 months 3 weeks ago by sbeaver.
9 months 3 weeks ago #234412 by sbeaver
Tried once more and are still thousands of error messages but they are all copies of these two:
Deprecated: Creation of dynamic property Kunena\Forum\Libraries\Forum\Category\KunenaCategory::$image is deprecated in ..../libraries/kunena/src/Database/KunenaDatabaseObject.php on line 128
Deprecated: Creation of dynamic property Kunena\Forum\Libraries\User\KunenaUser::$twitter is deprecated in ....libraries/kunena/src/User/KunenaUser.php on line 692
9 months 3 weeks ago #234413 by rich
Yes, I know that. Press the space bar after the installation to scroll all the way down. You will then see the menu and can call the Kunena Dashboard.
Scroll down again and you should see messages such as Database upgraded to version xxxx.
Then refresh your browser and the messages should be gone.
9 months 3 weeks ago - 9 months 3 weeks ago #234415 by sbeaver
Thank you for your patience.
I do not see any database upgrade messages. Visiting the Kunena dashboard and refreshing the browser (and clearing cache and cookies) the page renders but with 11 of the previously noted error messages. 9 "images", 2 "twitter"
I reinstalled from a fresh download but no change.
