- Thank you received: 2
Important Upgrade problems
I have used Kunena for about ten years. Over that time I have kept Joomla and Kunena up to date with only minor issues. Today I attempted to update from 6.3.10 to 6.4.8 and it did no go well. My whole Koomla 5 site has gone down with hundreds of "Creation of dynamic property Kunena\Forum\Libraries\Config\KunenaConfig::${social/Twitter/image etc} is deprecated" type errors being displayed. I cannot get to any part of my front end, nor the Kunena section of the backend. Attempting to upgrade the language pack gives an "Invalid extension" error.
Reverting to PHP8.1 fixes it but that is not a good solution. How can I fix this?
- Thank you received: 2545
These error messages should only be temporary and should disappear as soon as you open the Kunena dashboard and afterwards reload the page.
Deprecated: Creation of dynamic property Kunena\Forum\Libraries\Forum\Category\KunenaCategory::$image is deprecated in ..../libraries/kunena/src/Database/KunenaDatabaseObject.php on line 128
Deprecated: Creation of dynamic property Kunena\Forum\Libraries\User\KunenaUser::$twitter is deprecated in ....libraries/kunena/src/User/KunenaUser.php on line 692
Scroll down again and you should see messages such as Database upgraded to version xxxx.
Then refresh your browser and the messages should be gone.
I do not see any database upgrade messages. Visiting the Kunena dashboard and refreshing the browser (and clearing cache and cookies) the page renders but with 11 of the previously noted error messages. 9 "images", 2 "twitter"
I reinstalled from a fresh download but no change.
