- Thank you received: 2538
Question Please help me to solve this peculiar problem
Quote from here: forum.joomla.org/viewtopic.php?f=834&t=1015450#p3742472
This option should set the colour scheme (dark/light) of the frondend, and not the backend.
But it does not change the frontend, but instead it changes the backend colour scheme.
But you're right, if is selected dark mode in the backend doesn't solve the problem.
To solve this, we would need access to this user profile, since this error cannot be reproduced with other templates. I tested it with three different templates. But I have not tested with the Megainc template, as this is subject to a charge.
- Skywalker71
- With default colour:
- With changed colour:
- Thank you received: 165
So either adjust css, use a light JOOMLA template or look for a Kunena template that works with dark Joomla templates.
The Kunena codes are not overwritten, Aurelia is a transparent template so that it can be easily adapted to the Joomla template. In most cases, you only need a few CSS codes to customize the forum.
But it is just as easy to set up the forum so that it does not adapt to the Joomla template, as is desired in your case.
In my example, I use a light layout for Kunena again, but I still customized some things so that it harmonizes with the Joomla template (see image).
Add codes in the custom SCSS Edit SCSS | Kunena I hope this helps you.
