Question Forum slow when logged-in
I have noticed the following loading times:
Index ca 0.04 sec
Recent Topics ca 5 sec
Profiles up to 20 sec
But the longest loading time is for your main page Home (50 sec).
Recent Posts is a Kunena menu item that displays the same list as in your profile.Hi. the feature Show New posts is enabled,
But I think you mean the Kunena Latest module. Does this need to be displayed on the forum pages? It shows the same results that are displayed with the Kunena Recent Topics menu item.
Go to this module and remove the assignment to the Kunena menu items so that it is only displayed in Home. Then test your forum again.
Unfortunately, I cannot recognise with the browser tool where the long loading times come from, as no information is transmitted during loading.
Index ca 0.04 sec
But the longest loading time is for your main page Home (50 sec).Recent Posts is a Kunena menu item that displays the same list as in your profile.Hi. the feature Show New posts is enabled,
Thank you for the info... Even if I turn off all the latest posts modules, the forum still take between 5-9 seconds for a forum page to load, when the feature Show New posts is enabled.
Issue is still there.
When it is turned off, the entire site is flying.
It is enabled.Please enable it again. Perhaps the Lighthouse browser tool will show a better result.
Thank you.
As far as I know, you must have published multiple copies of Kunena Latest. A separate one for each country. Maybe they interfere with each other. Test it first with each one and if one works, add the next one and check the load time each time.
