Question Can't log into Kunena
3 years 8 months ago #227560 by OldCharlie
I'm again unable to log in to Kunena and make changes.   I can log into Joomla, and access the Dashboard, but I want to add a topic so have to log into the front end.   I made a video showing the problem.     3-3-2023 Unable to login to make changes to Kunena.
I followed the instructions from the archived topic with the link below where I give the configuration file.   Do you need another configuration file?
I want you to know that I had an archived "solved" topic that worked but now it doesn't.   It's here:  Unable to login to Kunena - Kunena - Kunena - To Speak! Next Generation Forum Component for Joomla
3 years 8 months ago - 3 years 8 months ago #227561 by OldCharlie
Replied by OldCharlie on topic Can't log into Kunena
Configuration file is attached.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: 4/30/2012
Kunena default template details : Crypsis | author: Kunena Team | version: 5.2.9 | creationdate: 2022-06-08
Kunena template params:
Kunena version detailed: Kunena 5.2.9 | 2022-06-08 [ Catraia ]
Plugins: Content - Kunena Discuss 5.2.2
Last edit: 3 years 8 months ago by rich.
3 years 8 months ago #227563 by rich
Replied by rich on topic Can't log into Kunena
Delete the menu items marked in red, they are not correct.
3 years 8 months ago - 3 years 8 months ago #227589 by OldCharlie
I checked on my Kunena Menus and the menus 195 and 196 are not present and were not when I first opened this topic.        So I just made another configuration report from Kunena"
Here is a video:   Do not have the menus you want me to delete.
Is there anything else that could be preventing me from logging into Kunena/
Last edit: 3 years 8 months ago by OldCharlie. Reason: Forgot to add link to a video showing I don't have the menus moderator wants me to remove.
3 years 8 months ago #227590 by Leen
Replied by Leen on topic Can't log into Kunena
hello have you also tried the Synchronize Users with Kunena tools .
And also checked whether there are no errors in Kunena tools Diagnostics?
And as for that kunena menu, take a look
whether nothing is in the trash or disabled with the search tool button
With kind regards
Leen
3 years 8 months ago #227592 by rich
One of these menu items is at the top of your main menu, the other menu item is in the trash of the main menu. You may not use Kunena menu items in other menus.
Menu Issues
Menu Tips
Time to create page: 0.190 seconds
