Question Can't log into Kunena
3 years 6 months ago #227598 by OldCharlie
Replied by OldCharlie on topic Can't log into Kunena
Hi, I have made a video showing I did your checks. I still cannot add any topics or log in the backend of Kunena.
See
billcory-pictures.s3.us-west-2.amazonaws...nena/brickKunena.mp4
3 years 6 months ago #227599 by OldCharlie
Maybe I should brick or delete Kunena from Joomla and start over, I'm currently using Joomla 3.10 and need to upgrade to Joomla 4.x.x So is there anyway to salvage some of the Kunena site? My plan is to update Joomla then reinstall Kunena's latest version. While doing so I will probably delete Kunena. Maybe I should delete Kunena now and first upgrade Joomla then reinstall and start all over again? I don't have much faith in Kunena and maybe should search for a different Forum software.
3 years 6 months ago #227600 by rich
Replied by rich on topic Can't log into Kunena
You have to decide that for yourself. Just so, the errors were not produced by Kunena because it does not create wrong menu items in other menus.
Kunena is easy to migrate, but you have to follow the steps exactly, otherwise you will have problems again. docs.kunena.org/en/basics/upgrade/upgrade-k6-0
Time to create page: 0.208 seconds
