Question CKEditor problem?
3 years 9 months ago - 3 years 9 months ago #227415 by anonymous01
Replied by anonymous01 on topic CKEditor problem?
You are very kind, thank you, rich. I suspected it, but didn't check it out. But you didn't have to waste your time on it. Purity III is a pain, my Purity css hacks file is over 500 lines long.  It doesn't work otherwise.
Joomlart has given me a nasty gift. You'd be surprised, but the information on List of supported 3rd extensions page is a fraud on users. Purity III doesn't support Kunena 6 at all (it took me a lot of effort to make this template work with Kunena 5). But it's impossible to reconcile Bootstrap 5 with the current version of Purity, this is nonsense.
When I upgrade to Joomla 4 and Kunena 6, I will be forced to bind Cassiopeia styles to the forum. Despite the fact that I chose Purity because of Joomlart declared support for Joomla 4. A lot of effort spent on Purity, I do not want to give it up now. Although Joomlart scam made a very unpleasant impression.
Last edit: 3 years 9 months ago by anonymous01.
3 years 9 months ago - 3 years 9 months ago #227428 by rich
Replied by rich on topic CKEditor problem?
Try t wit the t4_bs5_blank template from JoomlArt, it has fewer errors ().
Last edit: 3 years 9 months ago by rich. Reason: Link removed
The following user(s) said Thank You: anonymous01
3 years 9 months ago #227437 by anonymous01
Sure, I'll give it a try.
