Question CKEditor problem?
3 years 9 months ago - 3 years 9 months ago #227354 by anonymous01
Sometimes, when I try to edit a forum post, I get these errors in the console. I'm surprised because this is the first time I've seen it. Interestingly, of the several posts on the page, I can't edit only one of them. Help please.
Uncaught TypeError: Cannot read properties of null (reading 'type')     at e.onTagClose (ckeditor.js:1264:363)     at CKEDITOR.BBCodeParser.parse (ckeditor.js:1261:365)     at CKEDITOR.htmlParser.fragment.fromBBCode (ckeditor.js:1265:444)     at a.b (ckeditor.js:1269:226)     at a.m (ckeditor.js:10:246)     at a.<anonymous> (ckeditor.js:12:91)     at CKEDITOR.editor.CKEDITOR.editor.fire (ckeditor.js:13:286)     at a.setData (ckeditor.js:290:401)     at b (ckeditor.js:975:187)     at Object.wysiwyg (ckeditor.js:979:32) 9502:1 Refused to apply style from 'https://***********/media/kunena/core/js/plugins/copyformatting/styles/copyformatting.css?t=M8SC' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled. 9502:1 Refused to apply style from 'https://************/media/kunena/core/js/plugins/copyformatting/styles/copyformatting.css?t=M8SC' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
PHP 8.1, Joomla 3.10.11, kunena 5.2.14.
Last edit: 3 years 9 months ago by anonymous01.
3 years 9 months ago #227356 by xillibit
Replied by xillibit on topic CKEditor problem?
Can-you look in table #__kunena_messages_text to see the content of the message which you are not able to edit ?
3 years 9 months ago #227371 by anonymous01
Replied by anonymous01 on topic CKEditor problem?
Hello.
OK. Example one:
Example two:
3 years 9 months ago #227382 by rich
Replied by rich on topic CKEditor problem?
It is the size and alt attributes of the images that cause the errors. The CKEditor cannot do anything with html attributes. Without these everything is fine.
3 years 9 months ago #227385 by anonymous01
This is called "bug".
Do you disagree with me, rich?
All of these entries were made using the kunena editor.
3 years 9 months ago #227386 by rich
Yes, it is a bug in the editor. You can test it here. Empty the text from the test editor and enter this URL from your confitential text. Then press the button for the source code twice and the editor freezes. This bug has been reported a few times.
As an emergency solution, I recommend you go to Aurellia in the backend (tab BBCode) and select the SCEditor. This editor is not yet fully integrated, but you can edit the posts with it.
