Question Upgrading from Joomla 3.10 to Joomla 4.2.6
3 years 8 months ago #227300 by Slacker
When I was setting up a testupgrade site locally I had similar problem with Kickstart to extract the backupfiles due to certain files in the archieve. I used then a program Akeeba EXtract Wizard to unpack the archieve. Then I installed it.
3 years 8 months ago - 3 years 8 months ago #227305 by anonymous01
Akeeba Kickstart starts but it does not list my archive files
Hello.
There is no problem using the current version of Akeeba Kickstart. Unfortunately, I have almost no experience with Godaddy. But I see that Godaddy allows ssh.
My advice: go over ssh and run these commands (specify the correct path to the Akeeba Backup archive directory). I hope this solves all the problems.
sudo chown -R apache:apache /var/www/site_dir sudo chcon -R -t httpd_sys_rw_content_t /var/www/site_dir sudo find /var/www/site_dir -type d -exec chmod 0755 {} \; sudo find /var/www/site_dir -type f -exec chmod 0644 {} \;
Note. You need to change this path - /var/www/site_dir - so that it is correct.
Last edit: 3 years 8 months ago by anonymous01.
Time to create page: 0.254 seconds
