Question Upgrading from Joomla 3.10 to Joomla 4.2.6
3 years 8 months ago #227194 by OldCharlie
I've made backups and think I'm ready to upgrade,   But not sure about Kunena.
Here is a video of my situation at this point...do you think its' ok to upgrade?
billcory-pictures.s3.us-west-2.amazonaws...mla+Update+Check.mp4
3 years 8 months ago #227196 by rich
You are ready to upgrade, when all is green (passed).
Here are the steps for the upgrade: docs.kunena.org/en/basics/upgrade/upgrade-k6-0
3 years 8 months ago #227255 by Slacker
I upgraded to Joomla 4.2.6 for 2 weeks ago. Followed the descriptions for Kunena. And it was rather easy. One problem occurred the Kunena navbar was blank. It was recommended to renew the Kunena menu, which I did but did not help. For the Forum menu item choose Default menu item Index and then the Kunena menu items will populate the navbar.
3 years 8 months ago #227267 by OldCharlie
Wait, you said that didn't fix it and instead do this:
In case I still need to renew the Kunena Menu?
 If so is this the way to do it:
The easiest way would be to create all Kunena menu items new.
Go to the backend and:
1. Trash all existing menus and menu items that relate to your Kunena forum.
2. Empty the menu trash.
3. Use the Kunena Dashboard: Tools -> Menu Manager -> Restore Kunena Menu facility.
4. Publish the menu item created for you in your top-level/main menu.
docs.kunena.org/en/troubleshooting/menu-issues
docs.kunena.org/en/faq/kunena-menu
These steps removes also your customized menu items like Questions about Lindy Alerts?, you must create manually these again
3 years 8 months ago #227271 by rich
You have already upgraded to Joomla 4.2?
3 years 8 months ago - 3 years 8 months ago #227291 by OldCharlie
No,  I have not upgraded from 3.10 to 4.2. I have a meeting this morning to discuss the following error when trying to create a staging site so I can make the required changes to Joomla before the upgrade:
Akeeba Kickstart starts but it does not list my archive files
This usually means that the permissions of your site's root do not allow file listings. Please change the permissions of your site's root to 0755 or higher. If unsure how to do that, please ask your host; we don't know how each and every host works. You may also ask your host to give read and file listing permissions to your web root. They will either do that for you or tell you exactly how to do that.
On some hosts, we saw that it was necessary (on top of the above) to give 0755 permissions to the backup archive and all of its parts if any exist, e.g. file.jpa, file.j01, file.j02 etc. I know, this doesn't make any sense (0644 permissions on the file should work!) but it looks as if some hosts are grossly misconfigured. So, try setting your site's root directory permissions to 0755 and the permissions of your backup archive to 0755 as well. Kickstart should be left with 0644 permissions or you risk getting a 500 Internal Server Error.
Even after making sure the necessary permissions are 0755, I still get the error.   So I will not upgrade until I can get this resolved.   I'm waiting for GoDaddy support to contact me back, but its already been a couple of days.
Last edit: 3 years 8 months ago by OldCharlie.
Time to create page: 0.260 seconds
