Question Add files
4 years 3 months ago #224088 by Leen
Replied by Leen on topic Add files
I see in your kunena Kunena config settings: that there is still Blue-Eagel there,
but I think that is not good,
it must really be Aurelia as default template and save it
With kind regards
Leen
4 years 3 months ago #224104 by karloshull
Replied by karloshull on topic Add files
I changed the editor to CKeditor and default Aurelie but Add files is still not working
I did upgrade it from Joomla 3.
Any more ideas?
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload:
Joomla default template details : ja_findus | author: JoomlArt | version: 1.0.0 | creationdate: May 27th, 2022
Kunena default template details : Aurelia | author: Kunena Team | version: 6.0.1.1 | creationdate: 2022-07-09
Kunena template params:
Kunena version detailed: Kunena 6.0.1.1 | 2022-07-09 [ Git Repository ]
Third-party components: CommunityBuilder 2.7.3
Plugins: None
4 years 3 months ago #224105 by Leen
if you disable the Kunena - Community Builder plugin for a test, can you then upload an attachment or image ?
With kind regards
Leen
4 years 3 months ago #224113 by rich
Replied by rich on topic Add files
Are you using an optimization tool? I see only one css file. If so, test it without.
And if your Joomla template has own boostrap files, try it with disabled "Load bootstrap css" (in the Aurelia setting).
4 years 3 months ago #224137 by karloshull
I have disabled the Kunena - Community Builder plugin. Still not working
Switched to Aurelia, how do you disable bootstrap files?
4 years 3 months ago #224138 by Leen
strange that nothing helps.
If you use an htaccess with any adjustments, turn it off for a while by giving it a different name for a test whether it works.
And Rich also asked if you use eg plugin JCH Optimize if so also turn it off.
or take a look in your template to see if you see anything about Optimize and then turn it on or off and test
With kind regards
Leen
Time to create page: 0.184 seconds
