Question Add files
4 years 3 months ago #224073 by karloshull
Add files was created by karloshull
Hi
Im on kunena 6.0.1.1  Joomla 4.15
On Kunena the add files button doesn't work, nothing happens when I click on it.
I have tried it on Cassiopeia template too
Any ideas?
Karl
4 years 3 months ago #224077 by Leen
Replied by Leen on topic Add files
what exactly do you mean nothing happens when you click the add files button?
do you have some more info which template or which extra plug-ins maybe something for security website
or maybe your web browser is blocking it
With kind regards
Leen
4 years 3 months ago #224078 by karloshull
Replied by karloshull on topic Add files
Nothing happens - no file manager pops up or anything. No error
No extra plug-ins
I have tried it on a few devices.
everything else is working
4 years 3 months ago - 4 years 3 months ago #224081 by Leen
you also do not use jomsocial or community builder or easysocial?
and you are also sure that at Kunena Forum: Configuration tab uploads everything is set correctly? Allow Image Uploads > Registered Users Allow File Uploads > Registered Users maybe you can do the settings again and then press save close maybe that helps
can you post a Report Configuration here
www.kunena.org/docs/en/manual/backend/to...report-configuration
With kind regards
Leen
Last edit: 4 years 3 months ago by Leen.
4 years 3 months ago #224086 by karloshull
I am using the latest version of Community Builder
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload:
Joomla default template details : ja_findus | author: JoomlArt | version: 1.0.0 | creationdate: May 27th, 2022
Kunena default template details : Aurelia | author: Kunena Team | version: 6.0.1.1 | creationdate: 2022-07-09
Kunena template params:
Kunena version detailed: Kunena 6.0.1.1 | 2022-07-09 [ Git Repository ]
Third-party components: CommunityBuilder 2.7.3
Plugins: None
4 years 3 months ago #224087 by rich
Replied by rich on topic Add files
Try it with the CKEditor (Aurelia -> tab Bbcode)
Time to create page: 0.184 seconds
